![]() | Home > Technical (L322) > Fuel issues |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
http://www.fullfatrr.com/gallery/albums/us...6294~0.pdf
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
A bit more background
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Brilliant, thanks guys!
I think the pump cutting out while the nozzle is in the tank is not unusual for the car. Mine often cuts out so much that now I just stick the nozzle in upside down. There is a thread on here that someone started on the same subject. Some fuel station pumps deliver quicker than others.
Difficult to say about filling -- occasionally the pressure from a pump is too much -- it could be the 'wrong fuel' checker has been activated Current: 2011 FFRR Vogue SE 4.4 TDV8
Thanks for all answers!
to clarify;
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
The 4.4 TDV8 range is typically:
Hi Greg,
From my experience I agree with Greg on what miles are achievable.
@bushy 30; I am pretty sure they only did the right hand side now that you mention it : /
aggraa Member Since: 16 Apr 2018 Location: diss Posts: 33 ![]() ![]() |
I have fuelling enigmas too! In the UK Asda pumps fill ok, but Tescos and Morrisons take an age to fill, one of the reasons I got a TDV8 rather than a petrol car as I hate filling up
@aggraa yeah that makes sense to me too. Should be around 1000 km of range on full tank after highway driving when mpg is high.
40 mins is not possible -- even with two people -- they likely only managed to get to one of the connectors -- the others are closer to the pump -- so the pump has to come out (right hand side of tank) and then close to the float on the left hand side (also needs to come out, but out of the right hand side hole as it's connected to the pump) Current: 2011 FFRR Vogue SE 4.4 TDV8
