![]() | Home > Technical (L405) > Charging System Fault and single headlamp staying on |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
the side light is the drl and i'm pretty sure that bit of the headlight which you have illuminated is the high beam reflector..
DavidRR Member Since: 16 Dec 2017 Location: London Posts: 5 ![]() ![]() ![]() |
Thanks Stan. Updated title and text from side lamp to DRL.
no you misunderstand ,
Got you. Updated title again!
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Stan, early early cars had that light as a DRL (no signature DRL) and if not a super early car then that light is the cornering (AFS) lamp sir |
didnt know that....so thats my theory in the bin then... |
As expected, the battery was flat on Sunday morning and required a jump start to get going. More positively, I was able to start the car several times during the day so whilst there's a Charging System error, it does appear to be charging the battery. At various times the lamp stayed on, other times it went off, but it's on again now so there's another jump start on the horizon.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
I recall reading similar issues on a L322 some time ago (like 10 years ago).
