Home > Technical (L405) > Charging System Fault and single headlamp staying on
DavidRR
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
After two years of almost completely trouble free motoring, my L405 4.4 SDV8 has become upset at the thought of leaving me at the end of its PCP term and thrown one thing after another at me in the last month of ownership. Most have been handled but as of this morning I have "Charging System Fault" appearing on the dash.
Furthermore, I have a single headlamp lthat remains on quite dimly and flickers a little, see video below. This remains on whether the lights are in Auto or Off and with the car unlocked or locked. Pretty sure I'll be waking up to a flat battery and unfortunately I don't have anywhere I can trickle charge it from.
I had the Charging System Fault error a couple of weeks ago and reported it to my dealer a few days BEFORE the warranty ran out so it would be investigated and fixed when it was serviced just AFTER the warranty expired. Naturally it didn't occur on service day nor since (until today) and they never mentioned it.
I have to return the car to the finance company on Friday so keen to resolve before they send me an enormous bill. Appreciate any advice you guys might have.
Thanks in anticipation.
Post #536669 7th Dec 2019 5:24pm
the side light is the drl and i'm pretty sure that bit of the headlight which you have illuminated is the high beam reflector..
maybe a bad earth or a chaffed wire. ... - .- -.
Post #536670 7th Dec 2019 5:40pm
DavidRR
Thanks Stan. Updated title and text from side lamp to DRL.
I'm wondering if LR will address it under warranty since I reported to them before it expired on 22nd November.
Post #536672 7th Dec 2019 5:58pm
no you misunderstand ,
this is the drl,
the drl is also the side light.
the reflector bit that you have illuminated is [pretty sure] the high beam ... ... - .- -.
Post #536673 7th Dec 2019 6:11pm
DavidRR
Got you. Updated title again!
Going to check the car again shortly and am hoping it has magically switched off.
Post #536676 7th Dec 2019 6:33pm
Stan, early early cars had that light as a DRL (no signature DRL) and if not a super early car then that light is the cornering (AFS) lamp sir Thumbs Up
Post #536688 7th Dec 2019 10:32pm
didnt know that....so thats my theory in the bin then... Neutral ... - .- -.
Post #536698 8th Dec 2019 8:06am
DavidRR
As expected, the battery was flat on Sunday morning and required a jump start to get going. More positively, I was able to start the car several times during the day so whilst there's a Charging System error, it does appear to be charging the battery. At various times the lamp stayed on, other times it went off, but it's on again now so there's another jump start on the horizon.
Spoke to my mechanic today and before I bring the car in he suggested I do a hard reset by removing the cables from battery terminals and touching them together. I can see this is a very well documented process for L322 models but nothing about L405s. Before I go to the hassle, can anyone advise if they've done a hard reset on an L405 this way (or any other way)?
Thanks!
Post #536769 9th Dec 2019 12:20pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I recall reading similar issues on a L322 some time ago (like 10 years ago).
It was the battery getting low that caused the parking light to come on.
The guy fixed his charging issue, charged the battery fully, and it went away. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #536778 9th Dec 2019 1:22pm
