![]() | Home > Maintenance & Mods (L322) > Should u try to paint this.???? |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
I’d sand it down and repaint it, or give it to a body shop to do if you want a perfect finish. 2004 Autobiography TD6 Java Black |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35646 ![]() ![]() |
many cheap grills on ebay, i'd have a look there.. ... - .- -.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
I tried mi first paint job. Will post for comments;) Shipment is too much to Turkey from ebay:( But i discovered nasty rust under side grills.I guess not normal?? ![]() sold 06 td6 160k Sold 03 td6 260k |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 907 ![]() ![]() ![]() |
They’re just steel mounting brackets that can be removed (two bolts) & replaced cheaply |
Arghhh all was fine till i screwed corner of the grill while clear coating.
A tip for this job.
Looks good! 2004 Autobiography TD6 Java Black |
