Home > Technical (L322) > Possible progress with FBH after AGM battery install.
Andy
So I bit the bullet yesterday and fitted the 019 AGM that had been sitting in my garage for two weeks.
This morning I pressed the FBH remote as it as 0°. I could hear it shining under the battery and then for the first time- a ticking sound from the rear!
This time it ran for around 5 minutes. Cold air was blowing from the FBH exhaust and then the ticking stopped.
The fuel Guage was showing just under 1/4 full with 110 mile range so had it cut out due to low fuel perhaps?
As always, thanks for any replies 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536131 2nd Dec 2019 10:54am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Likely to be low fuel, yes Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #536133 2nd Dec 2019 11:19am
DrRob
Fill up and try again tomorrow Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #536137 2nd Dec 2019 12:06pm
Andy
I’ve never heard this ticking before so we are getting somewhere. If did tick slow to start off with, then started speeding up- is that normal? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536141 2nd Dec 2019 12:15pm
rjff
Ticking sounds fine, same as mine. The FBH seems to have to have two load levels, so I assume the pump starts on low and then to max if required. Cheers
Richard
Gap IIDBT
Post #536148 2nd Dec 2019 1:41pm
Andy
What’s the fuel level before it stops working? I think I read somewhere that it’s 1/4 of a tank? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536176 2nd Dec 2019 6:05pm
TJH1985
I would also be interested to know if the ATC module assesses fuel for the FBH, the workshop manuals don’t mention fuel levels only temperatures and voltage - but like Andy I feel I have read this somewhere. Ours will fire with the fuel light on I know that much. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #536185 2nd Dec 2019 6:48pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
My FBH ran fine yesterday with an indicated range of 60 miles left, if that helps. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #536251 3rd Dec 2019 12:55pm
Andy
Ah. Mine was 110 miles. I’m filling it up today so I’ll try it again tonight 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536254 3rd Dec 2019 1:11pm
Andy
Back to normal this morning. Half a tank of diesel and 3° outside and no FBH working. No ticking this time either. 😡 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536402 5th Dec 2019 9:28am
kooky_guy
Sounds like it's locked itself out. You may need to pull the fuse to reset it. It's in the underbonnet fusebox on mine.
It will lock itself out after 3 (I think) failed starts. Not sure if low fuel counts as a failed start, but I'm not entirely sure that would be the problem anyway - mine still worked the other night with 60 miles left on the range. 2010 4.4 TDV8 Vogue SE
Post #536441 5th Dec 2019 12:16pm
Andy
It’s a PITA to keep taking the fuse box cover off to access the fuse! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536444 5th Dec 2019 12:33pm
John w
If you start the engine from cold, can you detect any exhaust from the FBH ?
I'm pretty sure it should run then too, so you get toasty before the engine has warmed up fully.
This link is specific to the pre 2007 BMW engined cars, but think the principle is the same. There is a great deal of info in this post.
https://www.landyzone.co.uk/land-rover/fbh...ow.207143/
(My apologies if I'm not meant to post links to other sites) Too many toys, not enough time
Post #536452 5th Dec 2019 1:09pm
Andy
I’ll check that later when I get back. I have heard the ticking sound on occasion when I first start the car so it may be working on start up. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536465 5th Dec 2019 2:36pm
Andy
Pulled the fuse under the bonnet- still blowing cold. I give up! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536755 8th Dec 2019 10:18pm
