Home > Technical (L322) > Possible progress with FBH after AGM battery install.
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Gave up on mine but I think we may have the same problem, apparently the circuit boards burn out I get the ticking I get manual blower for about 2 mins on the timed climate and I've have and still get fault codes
Flame out
Circulating fan fault
I've said to myself Censored it until the spring and I'll try a second hand one
Post #536821 9th Dec 2019 6:03pm
Andy
Where are you getting fault codes from? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536838 9th Dec 2019 8:54pm
My FBH was playing up the other day, but I’m pretty sure it’s due to low battery.
New LR Agm battery sitting in the garage awaiting fitting.Will be interested to see if it works better as the new LR battery is only 90Ah vs 95 on the original. It’s the right one, part numbers follow through the superceded list......etc. We shall see. There is nothing that can't be fixed with a hammer😜😜
Post #536840 9th Dec 2019 9:01pm
Andy
I’ve just fitted an AGM. This one is a 95amps 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536843 9th Dec 2019 9:10pm
Interesting, LR one?
Looking on LRparts website that are all now 90ah with all the LR part numbers.
The one I have got from Lr is an Exide one, I think that the one in the car is a Varta.....so maybe they switched suppliers..... There is nothing that can't be fixed with a hammer😜😜
Post #536849 9th Dec 2019 9:27pm
Henda
Off my bt idd tool best bit of kit you can get Thumbs Up
Post #536869 9th Dec 2019 11:47pm
TJH1985
Did you rule out the FBH water pump in the end Andy? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #536886 10th Dec 2019 10:56am
Andy
Really? I can’t find any fbh fault codes on my IID tool. Where are they located? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536894 10th Dec 2019 12:49pm
Andy
No. Exide. £125 from euro car parts 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536895 10th Dec 2019 12:50pm
Andy
Water pump? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536896 10th Dec 2019 12:50pm
Andy
So I’ve just gone to pull Fuse 59 and it doesn’t exist on my car. It’s a spare slot by the looks of it. I assume my fuse box is no different to a 2008 car so why is it missing? What fuse do I pull to reset the FBH (apart from the one under the bonnet)
The pump did click again last night followed by the turbine noise and what’s best described as “room temperature” air blowing from the exhaust but only for around 2 minutes then is stopped again. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #537191 12th Dec 2019 1:35pm
New LR battery.
FBH all happy again. Smile
Just fired up got some ticking, then whirring/whining, air out of the vents and it was tepid.... however I’m happy/convinced it fired up and given a 10 min run would warm the car. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #537513 15th Dec 2019 3:23pm
DrRob
https://advancedbatterysupplies.co.uk/product/varta-g14/
Recommended AGM one. 95Ah
Was the LR dearer? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537518 15th Dec 2019 4:03pm
That is probably the same battery as the LR one which came out of mine, which was a Varys 95/850 in 019.
LR one was more but after faffing about with batteries on my 3.6 I figured that I would just put the LR one in. There is nothing that can't be fixed with a hammer😜😜
Post #537521 15th Dec 2019 4:14pm
Andy
I just tried something which I noticed made some difference.
I set the timer climate to come on at work. Set it for 1525hrs and sat in the car whilst it activated. I hear the fan come on and it sounded like it got louder. After around 2 minutes I started the car. Within 10 minutes the car was almost up to operating temperature. There was a faint whiff of something like stale water coming through the vents.
I’ve never known the car warm up so quickly though so I’m wondering if it carried on running when the engine started (like it’s supposed to?).
When I got home I checked with IID tool and no faults were logged. That’s not unusual to be honest as I’ve never seen a FBH fault.
I did check the operation within the IID tool and the test succeeded. I could hear the fan start up while the test was running. It used to fault (E7) when I ran the test before.
I’ll wait for it to cool down and try again later to see if it fires up.
Was the LR dearer?
I bought this one for £125 from Euro Car Parts:
https://www.tayna.co.uk/car-batteries/exid...gKFGvD_BwE 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #537525 15th Dec 2019 4:20pm
