![]() | Home > Technical (L322) > Competition time, it's let me down, AA on route, issue? :) |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
I'll take a punt on a loose connection, just to be different. |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 907 ![]() ![]() ![]() |
Having a similar age car, i'll go for the starter!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35604 ![]() ![]() |
battery and starter.. ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
AA man will turn the key & it will start first time. |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
I'd go battery :O Current: 2011 FFRR Vogue SE 4.4 TDV8
faz2kool Member Since: 11 Oct 2019 Location: Sheffield Posts: 42 ![]() ![]() ![]() |
AA probably still havent turned up..... ------------------------------------------------------
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3809 ![]() ![]() ![]() |
Starter motor.
Rex the RR Member Since: 15 Nov 2019 Location: Perthshire Posts: 43 ![]() ![]() ![]() |
I've been through all this and still not fully resolved. I had the infamous click, replaced the starter 18 months ago. Seemed better for a while but still the occasional click. Just recently replaced the battery and although no more clicks at the moment, the battery is not holding charge under load so next for me is the alternator..... |
Check the voltage at the starter solenoid terminal.
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
And the winner is.......
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
The 'battery seems fine but intermittently no reaction other than a click when pressing the starter button' on my 2012 WM was cured by fitting a new starter motor. It seems a very common fault. Note that the old motor goes back to LR for refurbishment and you get a credit for it against the price of the new one (at franchise dealers). Only Range Rovers since 1988 |
A replacement starter (Denso, same as original one) was £260 from site sponsors Opie.
