Home > Technical (L322) > Help please - dropped hose spring retaining clip!!! |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
John,
25th Nov 2019 1:17pm |
TDV8John Member Since: 08 Nov 2015 Location: Kent Posts: 19 |
OK thanks John, I'll just give it a bit more of a tug when I try again.
25th Nov 2019 3:24pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
counter intuituvely you push the clip inwards and the fitting should release. There is nothing that can't be fixed with a hammer😜😜
26th Nov 2019 6:24pm |
Oh right, that is very helpful advice thank you!
26th Nov 2019 6:27pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 863 |
I replaced my expansion tank (oil cooler gasket was leaking and had oily film on the inside of the expansion tank) requiring removal of that lower hose fitting, I also lost the same spring clip but luckily found it hiding in the subframe.
26th Nov 2019 6:58pm |
OK thanks again.
26th Nov 2019 7:02pm |
Ps if the clip is completely removed opposed moved into the ‘remove’ position, the fitting should just pull off. |
26th Nov 2019 7:03pm |
All sorted this morning with the advice above put into action.
1st Dec 2019 12:37pm |
Brill There is nothing that can't be fixed with a hammer😜😜
1st Dec 2019 12:53pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 397 |
Hi TDV8John,
1st Feb 2020 2:49pm |
Found the spring clip...
2nd Feb 2020 5:38pm |
