Home > Technical (L322) > Rear dog guard info (was needed, now for reference)
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Hi all,
I've discovered the retractable dog guard mounts for a car without reclining seats are different.
I'm therefore after a parts diagram, or part numbers for the mounts.
Cheers
John. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #535329 24th Nov 2019 4:10pm
John w
ok, so no replies, lets try a different approach Wink
Are there any owners out there with reclining rear seats that also have the retractable cargo net / dog guard fitted ?
I've paid the dealer a trip, and they gave me the part numbers, but these look exactly the same as those for non reclining seats, which are different (I will post some pics in a minute) Too many toys, not enough time
Post #535511 26th Nov 2019 2:12pm
John w
This is the standard cover. Note the cut out at the front corner to allow the seat to recline
The non reclining cover
And the metal fixing. Note the retainer is further back as the reclining seat load cover has a flappy bit at the front, so pivot is further back.
Worst case I simply cant fit it, just need to confirm one way or the other. Too many toys, not enough time
Post #535512 26th Nov 2019 2:23pm
John w
okay, scrap that, I think I've proven to myself its not possible.
I happened on this site :
https://allbrit.de/epc.cfm?PAGE=5010535A&a...E=EN#46506
which gives all parts lists on line.
The above link shows details for side bits and load tray for seats with recliner (which are clearly made of solid gold based on the price Rolling Eyes ), but there are no alternate bits listed for the load retention net Crying or Very sad Too many toys, not enough time
Post #535513 26th Nov 2019 2:31pm
mjdronfield
Yeah.... I’d say the luggage net isn’t compatible with the reclining seats. Even if you moved the bottom mounts to work, the top mounts in the roof would then not line up....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #535540 26th Nov 2019 6:53pm
John w
I had a bit more time to look at this today.
With the seats reclined they clear the cargo net.
Also the metal brackets can be clearanced to fit properly.
That just leaves the plastic cover.
I am going to have a go at doctoring them if I can get a spare set. Too many toys, not enough time
Post #535995 30th Nov 2019 6:42pm
g4mudman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Hi John
Good work watching this with interest as I pick my 2012 AB up on Sunday with reclining rear seats.
Be good to know if you manage to fit the cargo net.
Regards
Alan
Post #535998 30th Nov 2019 6:54pm
John w
Thanks Alan.
Good luck with the new car Thumbs Up
Cutting the alloy Base back to clear the spring bracket is simple enough.
Modifying the plastic covers is a bit more tricky, if it's to still look presentable.
My parcel shelf is ivory, but the seats are black at the top, so a black net casing doesn't look out of place.
The plastic covers come in black, parchment, sand and ivory (maybe other colours too)
The net casing is also in different colours. I've seen sand, ivory and black.
The alloy brackets are ~£16 each new, and the plastic covers for them are ~£40 new
You can see the parts on line here:
https://parts.jaguarlandroverclassic.com/e...ssist.html Too many toys, not enough time
Post #536001 30th Nov 2019 7:19pm
g4mudman
Thanks for the info John.
I'll have to look when I get the car and then see if I can find a s/h cargo net.
Post #536029 30th Nov 2019 10:37pm
John w
There are loads of nets for sale on the bay, in varying colours and conditions. Most don't come with the mounting bits though.
FYI a new net is in the order of 180 quid. Too many toys, not enough time
Post #536034 30th Nov 2019 10:54pm
