Home > Maintenance & Mods (L405) > 2013 Range Rover vogue reversing camera - help needed
Nickfel
Hi,
Not sure if anyone else has issues but I’ve just purchased a 2013 RR and the reversing
Camera is rubbish. Is there any mod or upgrade I can do to these to make hd? At present when it’s wet you can’t see out the camera (or if it’s bad light) ..
Thanks guys. And hello!!
Post #535471 26th Nov 2019 7:51am
Pez02
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I am also Interested in the above, having recently purchased a FFRR 13. Thanks Smile
Post #535480 26th Nov 2019 9:37am
Brian Considine
If it's rain/spray on the lens you could put some "Rainex" or similar on it to help a little. 2003 Range Rover Vogue TD6
Post #535483 26th Nov 2019 9:55am
the camera does get 'dirty' due the position it is in ....i know of a member who regularly wipes the lens when he walks past .. ... - .- -.
Post #535491 26th Nov 2019 10:46am
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
That's right, it quickly gets mucky being quite exposed. A quick wipe with a tissue makes a big difference.
Post #535518 26th Nov 2019 3:28pm
Nickfel
Thanks!
Post #535694 27th Nov 2019 11:17pm
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Hi
It took me a while of searching but I have bought two hoses and a camera mount from LandRover and installed a washer for mine (Last year Christmas present to me). If you go into any show room and look at the newer models I think from 2016 onwards the rear camera has a washer.
It works BRILLIANTLY Thumbs Up but not cheap - each hose was about £45 each, the camera mount was £10. The rear spoiler has to be removed and a hole drilled into the fibreglass boot lid Shocked . It sounds drastice but I manged all by myself. I would not be without it now.
Post #535770 28th Nov 2019 7:01pm
Did they move the camera up there or did you do that ?
Mine is at the bottom of the upper tailgate, just above the number plate.
It seems to pick up dirt easily so I wipe mine quite regularly....
Post #535772 28th Nov 2019 7:55pm
I've just had a look at mine and its got a wash nozzle next to it...didnt know that.... ... - .- -.
Post #535775 28th Nov 2019 8:08pm
Mariana Black
Hi Alistair
No I have not moved the camera washer, its located next to the camera above the number plate. The picture show where I had to remove the spoiler and connect the washer tubing into a new hole I had to drill.
3.0 14M5 Autobiography
Post #535878 29th Nov 2019 7:26pm
Makes sense - thanks Thumbs Up
Post #535879 29th Nov 2019 7:34pm
