Home > Maintenance & Mods (L405) > Does anyone want a winch mount for L405?
Page 2 of 5 <12345>
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
wow that's awesome!
Post #534867 19th Nov 2019 10:51pm
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
Is there any difference in the front bumper etc of the MY18 (is yours an 18?) v MY17??? 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #534884 20th Nov 2019 11:26am
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Mounting wise according to LR the bumpers mount identically and nothing has changed in the architecture from 2013 to 2019 in regards to the bumpers etc.
Post #534994 21st Nov 2019 8:22am
BlackPerth
Excellent thanks Charles 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #535106 22nd Nov 2019 9:58am
Charles89
Updated picture.. took her to Tixover to test everything out, and ended up recovering a pickup truck that got stuck. So I made use of my Rhino snatch block and winched him out from round a corner Thumbs Up
Post #535372 25th Nov 2019 6:27am
Looks fantastic Cool
Post #535373 25th Nov 2019 7:43am
verydisco
Superb!
You've got mail (well a PM)
Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #535401 25th Nov 2019 1:14pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Unnecessary quote removed
Great work. I admire your adventurous spirit with the FF and look forward to your posts on future conquests !
Post #535431 25th Nov 2019 7:10pm
thats a fair bit of extra weight on the front Charles, does it affect the steering? ... - .- -.
Post #535438 25th Nov 2019 7:59pm
Charles89
Everything was weighed and it totals just over 50kg + winch rope. But I opted for the synthetic dyneema rope, its stronger than the cable steel and far far lighter. I actually winched and recovered a ground out vehicle using a snatch block and it was incredibly effortless.
The only down side is not being able to fully see the drum and having to make sure you dont get a birds nest tangle up, so incrementally does it.
Handling wise I was concerned it would change the dynamics of the handling, but in reality it's barely noticeable, what was apparent from the full strip down of the front end, is how far back the engine really is and how far forward the front wheels/controls really are. If you take away the plastic bumper and stand next to the car front and rear you really do have a wheel on each corner of the car, so it's no wander the L405 is far more car like to drive on road than its predecessors... the more I pull off this car the more I respect its architecture and incredible engineering
When I was at Tixover yesterday, I watched 3 cars get stuck on the axle twister, a jimmny, a discovery 2 and a defender 110.. I crawled up to it in rock crawl mode (confident I had a winch of course) and put her in sport mode 2nd gear and gently held a small amount of throttle and let the computer do the work, my god does it make things look easy. Safe to say I think the audience that day were suitably impressed as it was all easy peasy, and also recovered a stuck vehicle Thumbs Up
Post #535440 25th Nov 2019 8:14pm
roberlar
Any cooling issues with the light bars and winch in front of rads or is all ok ?
Post #535444 25th Nov 2019 8:32pm
GGDR
Charles is that mega mount steel or aluminium?
. Cheers, Greg
Post #535447 25th Nov 2019 9:01pm
Charles89
No issues with cooling. Its absolutely fine, I guess the summer will be the true test.
The mount is all solid steel 8mm plate reinforced with 10mm ribs
Post #535466 26th Nov 2019 6:05am
BlackPerth
I am a bit nervous about the cooling impact in an Australian summer (40C plus). Especially towing. 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #535703 28th Nov 2019 6:32am
Charles89
You wont have an issue. Because the winch and mount only occupies the same surface area as the existing impact bar. So you loose no cooling. The reason cooling was asked in my situation was I have 2 light bars behind the grill so I am blocking airflow. But i have tested with the fans running and the draw is fantastic so I very much doubt there will be any issues at all. Especially if you have the AC on as the fans are always on with the AC and that will also keep things cool Thumbs Up
Post #535707 28th Nov 2019 7:52am
Page 2 of 5 <12345>
