Hi -you need to remove the top of the entire dashboard and then you can unscrew the instrument binnacle and change the bulbs. Its not as complicated as it sounds.
Should be detailed instructions in the wiki, but basically involves removing the side air vents, the end dash caps, and then the top of the dashboard. Not a big job but the vents are fiddly the first time. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
