Home > In Car Electronics (L322) > Instrument Panel Lights
On The Edge
Wales 2005 Range Rover Autobiography Td6 Mariana Black
Hi tonight with the instrument Panel light turned up full the Light on the right hand side of the 3 displays above the main message strip seem to have gone as can only just read the trip recorder display box but can not read the External temp display box
How do I get to the back of the Instrument Panel to try and sort it out?
Post #535048 21st Nov 2019 7:02pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Hi -you need to remove the top of the entire dashboard and then you can unscrew the instrument binnacle and change the bulbs. Its not as complicated as it sounds.
Should be detailed instructions in the wiki, but basically involves removing the side air vents, the end dash caps, and then the top of the dashboard. Not a big job but the vents are fiddly the first time. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #535125 22nd Nov 2019 1:50pm
On The Edge
Thanks so is it a replaceable bulb ?
Post #535146 22nd Nov 2019 4:12pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
What size/shape bulbs is this, would an LED upgrade be possible I wonder (to save dismantling the dashboard again in future)? "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #543446 9th Feb 2020 1:08am
