![]() | Home > Technical (L322) > Charging system fault / restricted performance.. |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
Confirmed the alternator has burned out.. Had to stop at lights when taking the car in and smoke was coming from under the hood, thankfully its not far to go.
OK, so the alternator has been replaced, but getting a bad screech on cold startup, and even though it drops off a lot after driving, there is still a small screech after driving for an hour. Could this be that the belts are not back n fully, or that the alt is not set right? |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Could be the belts or the idler and or tensioner pulleys.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Take it back and ask nicely to fix it |
^ Now there's a guy with a glass half full |
