![]() | Home > Technical (L322) > L322 2005 td6 Air suspension/abs woes FRONT LEFT |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 ![]() ![]() ![]() |
Just a thought, mine did the same when i had a very slight leak, it seemed the height sensor felt like the wheel was losing traction and triggered the abs light, and mine juddered would happen particularly after speed bumps. My bag eventually failed spectacularly and when replaced all corners were level and the issue went away.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6401 ![]() ![]() |
The voltage on the Front Left should be telling you something!
Slow Member Since: 09 May 2015 Location: Inverness Posts: 39 ![]() ![]() ![]() |
100% none of the bags leak, i have had a leaky bag on a previous one (and a Mercedes).I can leave it in offroad mode for a week without using the car and it doesnt move at all. Tried 3 sensors, new, used spare and known good and all have the exact same voltage/issues.
means nothing ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Surely the air would leak out if unused. Used to have a Mercedes with a leaky bag which would drop down over a few days. |
