![]() | Home > Technical (L322) > Heater issue on Auto |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
When On auto none of the dotted lights will be lit up.
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Thanks Daz, that's one less thing to worry about then! |
BackinBlack Member Since: 10 Dec 2018 Location: Manchester Posts: 18 ![]() ![]() ![]() |
My 2005 L322 lights up on auto, I checked it this morning. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
2011 = no lights when on Auto. I don't move it off that setting ever. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
My 2009 lights up on auto. Mine is a pre-facelift.
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
2011, no dots when on AUTO and both dot & line are lit, maybe there is a semi auto and full auto mode?
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
2007, dots on auto. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7861 ![]() ![]() ![]() |
If I remember right, on the earlier cats you could have manual fan speed and auto everything else.....or similar. You press Auto again and it goes back to full auto.
Thoroughly confused now! Mine's a facelift so it seems ike maybe the lights shouldn't be on when on Auto. Other thing is, the fan is running but it doesn't blow hard, not even when I put the temp on min or max. 7am this morning, -3 on the dash, and at 24 degrees it just puffs gently. Got warm enough but didn't try hard!
Irrespective of any setting, if you turn the fan up manually using the knob, the fan should increase.....end of.....
Max Defrost on cold mornings should blow the fans full pelt |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 ![]() ![]() ![]() |
2006MY should have dots lit on fan control according to fan speed so you've defo a fault.
It does run fast when I manually dial it up. I *think* it does for max defrost but I'll check tomorrow. 5.0 S/C Autobiography - now gone to pastures new.... |
Just reread your query, apologies, above when I was talking about lights I meant the ones in the Auto button. I see what you mean now.
