Home > Technical (L322) > Will car shut itself down if fuel gauge reads empty?
Gusfast
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Hi,
I am hoping one of you good people may be able to help. I have a 2010 3.6TDV8 with a very erratic fuel gauge (which never shows more than half full). Will it shut itself down if it reads Zero miles to empty (although there is plenty of fuel in it) ?
It suddenly dropped to zero today when stopped on a slope, and didn't cut out, but it was only for a few seconds untl I was on the level. I am hoping that it is just corroded fuel sender connections/wiring.
Thanks in advance.
Post #534381 15th Nov 2019 5:45pm
It will keep going until it physically runs out.
One bank holiday when everywhere seemed to be shut, I drove a bum squeakingly long way with zero miles to empty being displayed.
This thread may have some clues as to the cause.
Post #534383 15th Nov 2019 5:58pm
cass
Can’t be sure about yours but my 2011 4.4 started going into limp home mode when my sender unit failed showing zero even when half full
Post #534386 15th Nov 2019 6:31pm
Gusfast
Thanks Cass.
I'm not going to venture too far from home until it's fixed so limp mode wouldn't be the end of world. I just don't want it to die on me!
Post #534389 15th Nov 2019 6:39pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I wonder if you could stick a resistor across the faulty sensor plug as a temporary measure? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #534392 15th Nov 2019 7:06pm
Gusfast
Hi Mike,
Hadn't thought of that. As it's due into the garage in a couple of weeks I will just keep my fingers crossed till then.
Many thanks
Guy
Post #534394 15th Nov 2019 7:20pm
cass
The resistor trick does work. I got 2 variable resistors (one for each sender). They were less than £1 each at Maplins at the time then tweaked them to get a reading on the gauge just so that I could run the tank down before doing the repair. It worked that well that I ended up using the car like that until the weather improved.
Post #534399 15th Nov 2019 7:44pm
Gusfast
Thanks Cass. Good to know.
Post #534403 15th Nov 2019 8:59pm
