![]() | Home > Technical (L322) > Will car shut itself down if fuel gauge reads empty? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
It will keep going until it physically runs out.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 750 ![]() ![]() |
Can’t be sure about yours but my 2011 4.4 started going into limp home mode when my sender unit failed showing zero even when half full |
Gusfast Member Since: 24 Jan 2017 Location: Somerset Posts: 35 ![]() ![]() ![]() |
Thanks Cass.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
I wonder if you could stick a resistor across the faulty sensor plug as a temporary measure? 2016 Skoda Octavia VRS Estate
Hi Mike,
The resistor trick does work. I got 2 variable resistors (one for each sender). They were less than £1 each at Maplins at the time then tweaked them to get a reading on the gauge just so that I could run the tank down before doing the repair. It worked that well that I ended up using the car like that until the weather improved. |
Thanks Cass. Good to know. |
