![]() | Home > Technical (L322) > Part Identification Help Please. |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
Its the Variable Valve Timing Solenoid seal , to replace the seal its cam cover off as getting it from the top is fraught with damaging issues |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Thanks gavinn. Much appreciated. |
Just a quick update: I have been told (by the local Indie) that LR do not sell the Valve Timing Solenoid seal separately and so will necessitate purchasing a whole new cam cover (Or something expensive like that) if I want it fixed.
Land Rover don't do them separate , but Jaguar do , and as its exactly the same engine and fit then you just use a Jag part number , the one you need is AJ82856
Very helpful indeed! Many thanks Gavinn. |
