Home > Technical (L322) > Part Identification Help Please.
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
I have oil weeping from somewhere on the nearside of my FF engine. It seems to be coming from this part (see Yellow circle in attached picture). Edit: It's on the side (nearside) towards the front upper part of the engine.
Can someone tell me what this part is/does please? And is it serious to fix (i.e. expensive Shocked )
Many thanks.
Post #528518 19th Sep 2019 9:31am
gavinn
Its the Variable Valve Timing Solenoid seal , to replace the seal its cam cover off as getting it from the top is fraught with damaging issues
Post #528532 19th Sep 2019 1:31pm
Gyre8
Thanks gavinn. Much appreciated.
Post #528535 19th Sep 2019 1:42pm
Gyre8
Just a quick update: I have been told (by the local Indie) that LR do not sell the Valve Timing Solenoid seal separately and so will necessitate purchasing a whole new cam cover (Or something expensive like that) if I want it fixed.
I'm not experienced enough to tell if this is correct. So slight oil weep continues for now.
Post #534277 14th Nov 2019 9:27pm
gavinn
Land Rover don't do them separate , but Jaguar do , and as its exactly the same engine and fit then you just use a Jag part number , the one you need is AJ82856
Hope this helps
Post #534339 15th Nov 2019 11:17am
Gyre8
Very helpful indeed! Many thanks Gavinn.
Post #534345 15th Nov 2019 11:49am
