Home > General > MY2011 vs MY2012
neilrjones
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
MY2011 vs MY2012
Hi all,
I’ve tried searching but can’t find what I’m after - could someone steer me towards any significant differences between the MY2011 FF and MY2012 please?
Thanks a million for your help Smile
Neil
Post #534308 15th Nov 2019 8:14am
GGDR
in simple terms:
- spec (options included vs extra) varied quite a bit
- cosmetically black infill plastic colour inside headlights plus other bits like grille surround (MY11 is grey) giving the 2012 front a blacker look. Also door cards have Range Rover lettering inlaid in metal within the piano black sections. Cheers, Greg
Post #534309 15th Nov 2019 8:18am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
A late built 2011 has a lot of the same standard spec as 2012 rear lights front lights interior a little different as said door cards bu more down to Vogue, SE or Autobiography and what they paid for as an extra when car was orderd?
Post #534317 15th Nov 2019 9:24am
Baltic Blue
The spec of 2011 and 2012 L322 models seems very random and even varies within model type.
You need to prepare a list of options and tick them off as you view any potential purchase.
My 2011 VSE has a single view screen, but most 2012 models seem to have dual-view.
My 2011 has a fan unit fitted to the battery control unit, but 2012 models don’t have one fitted.
The list goes on.....
Post #534319 15th Nov 2019 9:53am
neilrjones
Wow - had a feeling this wasn't a straight forward question! The TV variant is especially random - I was under the impression this was standard, even my old 2010 FF had it...
My research continues - who wants to work on a Friday anyway?!
Thanks for the replies guys.
Post #534323 15th Nov 2019 10:04am
GGDR
Indeed; MY2012 like all model years started late 2011
Confused yet?
. Cheers, Greg
Post #534324 15th Nov 2019 10:08am
Baltic Blue
Other options to check that vary model to model...
Addapaptive cruise control.
Heated and cooled front seats.
Headlights
Sound system.
Post #534329 15th Nov 2019 10:38am
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
I have a 2012 MY registered in March 2012, its a vogue model but has :
Adaptive cruise
Heated and Cooled front seats
A thermal windscreen (in additional to normal heated screen)
A single view TV
Auto dim/dip mirrors
So actually very close to a 2011 Vogue SE spec
The build sheet seems to say it was ordered with a "special value pack e" what ever that was.
I think the trick is to ignore model and just see what its actually got fitted.
Roger
Post #534334 15th Nov 2019 11:11am
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Yes just been through this myself, did quite a bit of research and my
main finding was there seems to be little consistency! Main thing I found was the colour coding. IMO it does look a lot better, however, it’s easily something you can have done so I wouldn’t use that as a reason to only consider MY12 cars.
Post #534337 15th Nov 2019 11:47am
There's also some bodywork differences available like the extended back on my 12 AB
 Mike - MPx
Post #534413 16th Nov 2019 12:08am
mjdronfield
That was also available on 2011 cars. It’s the Exterior Design Pack.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #534421 16th Nov 2019 7:46am
M@r]{
Yes exactly, that’s the optional design pack rear bumper with exhaust trims. The full
Kit comes with a different lower front bumper section and grill, along with some subtle
Side extensions...... oh and a different style 20” wheel
Post #534423 16th Nov 2019 8:42am
stu
My 2012 MY Vogue had normal single view TV, but SE leather and heated/ cooled seats. As stated just a spec thing and how much the original owner wanted to spend. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #534981 21st Nov 2019 7:49am
eternaloptimist
Definitely very confusing.
I have a late 2012 Westminster, which I compared with an apparently identical car.
Mine has the DVD (useless to me) and deployable side steps (useful and cool) - the other one had neither... An early 2012 model, albeit same colour.
The obvious missing 'toy' is the adaptive cruise, which I would like to have.
There are loads out there, however I bought mine from a LR Dealer with a cracking warranty, which has paid off.
One turbo, key and a few other bits agreed or under negotiation.
I would definitely recommend a good warranty. A purchase saving may look ok, however there are lots to go wrong on these beasts.
Mark 2012 Westminster - Orkney Grey
Post #535047 21st Nov 2019 7:56pm
