Home > Maintenance & Mods (L405) > Battery Low warning
Chalky
Battery Low warning
My car is 19 months old and I have a Low Battery warning and since then the tailgate doesn't always work properly.
Can I charge the main battery under the spare wheel/Compressor or is that taboo?? All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #532600 29th Oct 2019 10:15pm
Do you not have a post under the bonnet on an 18MY? The JLR genuine trickle charger would connect directly to the lower battery (under the spare wheel) so charging that battery directly should be fine Thumbs Up
Post #532604 29th Oct 2019 10:58pm
Phil.
I use a battery conditioner or a solar charger connected directly to the battery under the spare wheel and it’s fine (MY17). MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #532622 30th Oct 2019 8:55am
Chalky
Thanks Craig. Yes. I have a post under the bonnet but what is that for? Not to charge the battery??? Sorry, I'm not a car mechanic, I just drive it!! Whistle
I have a Ctech charger which is identical to the LR branded charger, so I presume I can use that? All LR cars from 1984
Post #532674 30th Oct 2019 5:43pm
The posts are so you can conveniently connect jump leads - they are just cabled directly to the battery.
I have a CTEK socket connected to mine - you can just unscrew them & connect a fixed cable - or just use the clips onto the posts
There's positive post under a cover and a negative post in front of it.
Ignore the thick red cable - I also have an Anderson connector to easily connect jump leads
It's by far the easiest way to charge.
To get to the main battery, you have to remove the spare wheel & even then, the positive terminal isn't exactly accessible
Post #532676 30th Oct 2019 5:49pm
Chalky
Thanks Alistair, so I can just connect the Ctech onto the posts? All LR cars from 1984
Post #532681 30th Oct 2019 6:14pm
Yes - flip the plastic cover to get to the + terminal and the -ve is the exposed one
Post #532683 30th Oct 2019 6:38pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Heres a strange question, on my Bentley the Ctek charger plugs direct into a aux/cig socket in the boot, and the Aston Martin has a similar set up in the boot too. When i spoke to Ctek they said i could charge the Bentley through the boot or any aux/cig socket as long as it had a permenant feed. Ctek also do sell a cig charger adaptor, so the big question is; Is it possible to do the same with the L405 as seems like a lot of faf to be lifting boot floors and opening bonnets to connect a trickle charger? Also in response to the question about Ctek chargers, i would contact Ctek direct as to what model is correct for the L405 as i have two completely different chargers for the Bentley and Aston, something to do with battery size and charging capacity and load etc. In my experience Ctek are very helpful.
Post #532688 30th Oct 2019 7:36pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
First of all, It's not too encouraging that we should need an intelligent charger on the L405, however I've had one connected on an old '94 911 for the last five or so years via the permanent battery connectors with quick connect and it's a matter of seconds to connect / disconnect. And it certainly does the job as prior to this, the immobiliser was drainng the battery in two weeks and I was buying a new battery every year or so.
Post #532692 30th Oct 2019 8:06pm
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Do you have towing electrics, if so you can use the various adapter cables including ctec that are available from the site shop. Thumbs Up
Post #532717 31st Oct 2019 7:46am
Tow electrics is an option unless you have a deployable tow bar - with those, the electrics are not accessible with the tow bar stowed......
Not sure if the boot 'cig lighter' socket is permanently live or not.
I've only ever charged mine once - and that was to test the lead I'd connected - so I don't find opening the bonnet too onerous a task Whistle
Post #532718 31st Oct 2019 7:55am
Mr Tee
I have to charge mine roughly once per month. If the wife is using it just to go to work, it will quickly discharge over one week. Diesels really hate short journeys..
Post #532721 31st Oct 2019 8:23am
Chalky
Thanks Alistair Thumbs Up Thumbs Up All LR cars from 1984
Post #532730 31st Oct 2019 9:53am
The simple answer is No DrF... The aux/cigar lighters all power down some minutes after shut down... I have a JLR CTek charger that comes with wiring and a socket directly to the battery in the boot... The socket then gets mounted into a side panel... Thumbs Up
Post #532736 31st Oct 2019 10:54am
Yep, just connect tp the post and all will be fine...
I have a charger on the side of my ramp that i connect to the post under the bonnet of all L405's whilst here... A, it saves the battery low warnings! Grrr! and B, it conditions the batteries and gives extra life Thumbs Up
Post #532737 31st Oct 2019 10:57am
