Home > Maintenance & Mods (L405) > Battery Low warning |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Do you not have a post under the bonnet on an 18MY? The JLR genuine trickle charger would connect directly to the lower battery (under the spare wheel) so charging that battery directly should be fine |
29th Oct 2019 10:58pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 787 |
I use a battery conditioner or a solar charger connected directly to the battery under the spare wheel and it’s fine (MY17). MY23 D350 HSE
30th Oct 2019 8:55am |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 903 |
Thanks Craig. Yes. I have a post under the bonnet but what is that for? Not to charge the battery??? Sorry, I'm not a car mechanic, I just drive it!!
30th Oct 2019 5:43pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7954 |
The posts are so you can conveniently connect jump leads - they are just cabled directly to the battery.
Ignore the thick red cable - I also have an Anderson connector to easily connect jump leads
It's by far the easiest way to charge. To get to the main battery, you have to remove the spare wheel & even then, the positive terminal isn't exactly accessible
30th Oct 2019 5:49pm |
Thanks Alistair, so I can just connect the Ctech onto the posts? All LR cars from 1984
30th Oct 2019 6:14pm |
Yes - flip the plastic cover to get to the + terminal and the -ve is the exposed one |
30th Oct 2019 6:38pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1433 |
Heres a strange question, on my Bentley the Ctek charger plugs direct into a aux/cig socket in the boot, and the Aston Martin has a similar set up in the boot too. When i spoke to Ctek they said i could charge the Bentley through the boot or any aux/cig socket as long as it had a permenant feed. Ctek also do sell a cig charger adaptor, so the big question is; Is it possible to do the same with the L405 as seems like a lot of faf to be lifting boot floors and opening bonnets to connect a trickle charger? Also in response to the question about Ctek chargers, i would contact Ctek direct as to what model is correct for the L405 as i have two completely different chargers for the Bentley and Aston, something to do with battery size and charging capacity and load etc. In my experience Ctek are very helpful.
30th Oct 2019 7:36pm |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
First of all, It's not too encouraging that we should need an intelligent charger on the L405, however I've had one connected on an old '94 911 for the last five or so years via the permanent battery connectors with quick connect and it's a matter of seconds to connect / disconnect. And it certainly does the job as prior to this, the immobiliser was drainng the battery in two weeks and I was buying a new battery every year or so. |
30th Oct 2019 8:06pm |
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 59 |
Do you have towing electrics, if so you can use the various adapter cables including ctec that are available from the site shop. |
31st Oct 2019 7:46am |
Tow electrics is an option unless you have a deployable tow bar - with those, the electrics are not accessible with the tow bar stowed......
31st Oct 2019 7:55am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2659 |
I have to charge mine roughly once per month. If the wife is using it just to go to work, it will quickly discharge over one week. Diesels really hate short journeys.. |
31st Oct 2019 8:23am |
Thanks Alistair All LR cars from 1984
31st Oct 2019 9:53am |
The simple answer is No DrF... The aux/cigar lighters all power down some minutes after shut down... I have a JLR CTek charger that comes with wiring and a socket directly to the battery in the boot... The socket then gets mounted into a side panel... |
31st Oct 2019 10:54am |
Yep, just connect tp the post and all will be fine... I have a charger on the side of my ramp that i connect to the post under the bonnet of all L405's whilst here... A, it saves the battery low warnings! Grrr! and B, it conditions the batteries and gives extra life |
31st Oct 2019 10:57am |
