Home > Technical (L322) > Severe loss of power
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
On 3 occassions now I have had a severe loss of power, the engine judders and feels like it is not running on all cylinders and is about to stall. Happens with cold and fully warmed up engine, usually at below 30mph. No warning lights or gongs just the car slows to a crawl and "kangeroos" for 5-10sec and then off it goes again as if nothing has happened. It's been to the local dealer who can find nothing wrong and there are no faults logged in the ECU. It did it again this weekend. I haven't misfuelled it. Anybody any ideas? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #53269 7th Mar 2011 9:33am
cant help with a diagnosis tim but its worth while having some kind of video recording device handy when you journey so that you get 'proof' of whats happening..good job its under warranty though.. ... - .- -.
Post #53272 7th Mar 2011 9:47am
Tim in Scotland
I wondered if it might be something to do with the Diesel Particulate Filters (if the car has them!) even though my car rarely does much stop/start city driving (certainly not enough to clog up the DPF) and it is going through a check cycle. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #53278 7th Mar 2011 10:20am
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Have had exactly the same problem...told Stratstone about it when the car was in for its first service 2 weeks ago they say that nothing showed up during the diagnostic check and as far as they are concerned there isn't a problem!!!! Shocked
Post #53279 7th Mar 2011 10:20am
kriswilson
Scotland 2007 Range Rover Vogue SE Supercharged Java Black
Sounds like the same problem i had which turned out to be a fuelling issue. I changed both the secondary fuel pump and also the fuel filter and it seems to have solved the problem for now.
Post #53286 7th Mar 2011 11:12am
Tim in Scotland
Jee the car is only just a year/7600 miles old, I hope it isn't a fuel pump problem on so young a car 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #53331 7th Mar 2011 2:27pm
Tim I had a similar thing on my TD6, and that was the auxiliary fuel pump. Discovery 4 HSE
Post #53338 7th Mar 2011 2:56pm
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
Seem to be getting the same with my TD6 only happened today for the first time but now doing it all the time.
Happens mainly when over 35000 revs. RRUK does this sound like the problem you had with your TD6? will be getting it into a specialist next week but is they anyway for me to check this first?
http://gallery.me.com/paul_harland/100010
Range Rover Vogue TD6 2002 "52"
Bonatti Grey
Post #54281 12th Mar 2011 5:16pm
johnatandy
England 2005 Range Rover Vogue 4.4 V8 Oslo Blue
It will sound quite bad over 35,000 revs Very Happy
Post #54283 12th Mar 2011 5:26pm
paul_h_8
Laughing maybe an extra zero added, my bad
Bonatti Grey
Post #54288 12th Mar 2011 6:17pm
