Home > Technical (L322) > Shudder from Transmission |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35292 |
drive shafts or front diff, have you had yours done under warranty.. ... - .- -.
7th Mar 2011 9:29am |
This topic has been covered a fair few times, there is a detailed "how to" here somewhere. The GM box requires a fluid change every 50K - LR say the box is sealed for life - this is the life of the warranty. I've covered this various times in the past, recently here: http://www.fullfatrr.com/forum/topic4805.h...oil+change If you do the change yourself make sure you use genuine parts and exactly the correct fluid (listed in the WiKi). Don't take it to a Land Rover dealer, they wont do it, don't take it to a LR Indy because more than likely they won't have ever done one and the oil levels is a PITA to get right. Search yellow pages for a gearbox specialist as they will have worked on your box or variants of. The danger is that someone who doesn't know what they are doing will short or over fill it and it will pop after 5K. Expect to pay £125 - £175 |
7th Mar 2011 9:58am |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 |
Better go in today then tomorrow, because it could happen any second
7th Mar 2011 1:23pm |
