Home > In Car Electronics (L322) > Code abs module, Td6 2002. |
Loyola1988 Member Since: 04 Mar 2019 Location: PARIS Posts: 8 |
thanx i'll try this week end |
26th Oct 2019 3:25pm |
No luck for me it still won't work maybe the argument is bad mine is a 03 V8 any body can give me the rgiht argument with tool32? |
29th Oct 2019 1:29pm |
tveitan Member Since: 10 Dec 2016 Location: Norway Posts: 47 |
That's too bad. You're the second one who hasn't had any luck trying this. The argument is from, and used on a Td6. Tried it with two separate modules and it works fine. 2002 Range Rover Td6 |
29th Oct 2019 3:17pm |
Hello how did you pick up the argument? |
7th Nov 2019 3:26pm |
Trombots Member Since: 24 Jun 2020 Location: Anglesey Posts: 1 |
Worked fine on my 2004 TD6 too! A real lifesaver, (well saved a few quid anyway!). Many thanks. I would really like to know if there is a reference guide somewhere for DSC_L30.prg. Must be able to do lots of other funky stuff with it. Cheers, Ed |
24th Jun 2020 8:07am |
Hi. I found it when reading the config file from another RR Td6 2002 Range Rover Td6 |
25th Jun 2020 1:18pm |
Good to hear! I would like to know that as well 2002 Range Rover Td6 |
25th Jun 2020 1:48pm |
