Home > In Car Electronics (L322) > Code abs module, Td6 2002.
tveitan
Norway 2002 Range Rover HSE Td6 Oslo Blue
Hi! yes, it is Toolset 32. The file should be located in EDIABAS>ECU folder. the file is named DSC_L30.prg. Once you locate the file, you load it. It opens a new window where you can select different jobs. scroll down to coden_schreiben. Click it. On the right you will se a box where it says Argument. Just below there is a box where you can enter text. in that box you type 07, E0
Hit F5 key. Thats it. You Also need to calibrate steering angle sensor, if you haven't done it allready.
Hope this helps Very Happy 2002 Range Rover Td6
Post #531885 23rd Oct 2019 7:17am
Loyola1988
France 2003 Range Rover Vogue 4.4 V8 Giverny Green
thanx i'll try this week end
Post #532191 26th Oct 2019 3:25pm
Loyola1988
No luck for me it still won't work maybe the argument is bad mine is a 03 V8 any body can give me the rgiht argument with tool32?
Post #532545 29th Oct 2019 1:29pm
tveitan
That's too bad. You're the second one who hasn't had any luck trying this. The argument is from, and used on a Td6. Tried it with two separate modules and it works fine. 2002 Range Rover Td6
Post #532557 29th Oct 2019 3:17pm
Loyola1988
Hello how did you pick up the argument?
Post #533433 7th Nov 2019 3:26pm
Trombots
Wales 2004 Range Rover Vogue Td6 Adriatic Blue
Worked fine on my 2004 TD6 too! A real lifesaver, (well saved a few quid anyway!). Many thanks.
I would really like to know if there is a reference guide somewhere for DSC_L30.prg. Must be able to do lots of other funky stuff with it.
Cheers,
Ed
Post #558811 24th Jun 2020 8:07am
tveitan
Hi. I found it when reading the config file from another RR Td6 2002 Range Rover Td6
Post #558983 25th Jun 2020 1:18pm
tveitan
Cheers,
Ed
Good to hear! I would like to know that as well Laughing 2002 Range Rover Td6
Post #558988 25th Jun 2020 1:48pm
