Home > Technical (L322) > When it rains, my car she breaks |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
I would try having a look in the height sensor connecting plug / socket
26th Oct 2019 3:18pm |
Brut 666 Member Since: 21 Sep 2019 Location: Kent Posts: 5 |
Thanks for your welcome and thanks for thr reply.
26th Oct 2019 5:08pm |
You appear to have resolved the rear speed sensor problem by replacing the sensor?
26th Oct 2019 5:29pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
Have you unplugged the ABS socket and checked for corrosion on the spikes? I have a 4.4 V8 petrol and I got every light under the sun. Took it to the stealer who said “really sorry sir, your ABS unit is fubarred and needs replacing. That’ll be £1,000 please.” After I respectfully told him what he could do with his highly flawed synopsis, I took the socket off and found that, due to its design, it sits upside down and catches water!! (You couldn’t make it up!🧐)
26th Oct 2019 6:05pm |
Thanks for the replys chaps. So just to be clear, I've changed the nsr abs sensor and nsr hight sensor with genuine parts. And when it rains I still get the abs fault on the nsr rear. When it faults my solus shows the nsr abs sensor as not working, as in the live read shows the other 3 sensors displaying the mph and the nsr on 0. Its funny you say about the abs sensor plug positioned in the black box in the inner wing. This afternoon I turned it round so the big rubber elbow on the hub side of the plug was at the bottom and the thin wired end thats in the car facing upwards as I can't see were else water could get to it. |
26th Oct 2019 9:44pm |
Anyone with some advice at all? It's raining so got the lights up again and my solus says, nsr abs sensor. Starting to bum me out now. |
1st Nov 2019 10:06pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I would put my money on water getting into an electrical connection as previously mentioned. It won't need a lot to cause an issue. Try waterproof grease etc. |
2nd Nov 2019 9:48am |
