![]() | Home > Maintenance & Mods (L322) > The dredded oil cooler leak !!! |
ColinB139 Member Since: 02 Apr 2019 Location: Merseyside Posts: 1 ![]() ![]() ![]() |
faz2kool Member Since: 11 Oct 2019 Location: Sheffield Posts: 42 ![]() ![]() ![]() |
Hi All
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
Sheffield Prestige fixed mine. They have done loads since..... 2011 Range Rover Vogue SE 4.4 TDV8
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Green Oval in Leeds too. Take it to someone who knows these cars inside out. Not just any old mechanic. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
MJdronfield, thanks for the reply. Ive left a message with Sheffield Prestige. Did they replace the gasket on yours or the whole unit?
It was in a while as my oil cooler was cracked. They ordered one from Gordon Lamb and that arrived damaged, and I needed the coolant flushing out about 4 times to get rid of the oil......
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Wow, for that price I hope its fully fixed. |
That was Feb 2016. No issues since.
I know this is not relating to an oil cooler leak however the specialist garage I took my car to sort the leak out also changed my front disc and pads. Please have a look at the pic of the front pads that they fitted. The pad.has fallen forward a d is grinding on the disc. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Thank you Craig. Brakes are messed up now |
So after a week being stood at my local indy... he diagnosed the leak to be coming from the sump and not the oil cooler. Has anyone ever heard of this??.
Yes, I have heard of sump gasket leaks.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
