Home > Technical (L322) > DPF full. see dealer message out of the blue.Sensor failure? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3543 |
I'd have those hoses off and look very closely of cracks. Sometimes they crack underneath or underneath the clips. So just because there's no dust/debris doesn't mean you don't have an air leak.
24th Oct 2019 7:40pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3156 |
So, just been for another test run having checked the plenum pipes are fitting ok, the rear DPF sensor connects properly, changed the oil and filter and re-set the service indicator. Prior to the oil change and reset, the oil dilution factor was 12 (I read somewhere a reading of 7 is tip-over point!) this now read zero again.
27th Oct 2019 3:18pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3768 |
My first thoughts....
27th Oct 2019 4:43pm |
How long had the oil been in to get to a dilution figure of 12 ?
27th Oct 2019 4:54pm |
The car was given a major service exactly 1yr ago and less than 8.000 miles travelled.
27th Oct 2019 5:14pm |
Wow,
27th Oct 2019 6:09pm |
That’s interesting about the speed variation. I wouldn’t have thought it would make any difference as long as you were over the min speed.
27th Oct 2019 6:20pm |
What model phone do you use to take easy screenshots?
28th Oct 2019 10:27am |
It’s a 2018 iPhone XR. It’s just a finger and thumb squeeze on the buttons either side. Think I sent you photo of my rig up on the dash already ? |
28th Oct 2019 12:14pm |
Thanks, I will look out for one when the time comes to update my iPhone .
28th Oct 2019 12:29pm |
