![]() | Home > Technical (L322) > Park Heating |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Fox,
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Fox
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
It's amazing what you can find if only you look! ![]() Mitigating circumstances m'lud, as I've only had the fattie for a month or two & just back off a three week holiday so I haven't really had too much time to get acquainted properly. So, I had a look in the boot & there she was, so I'm assuming all I need to do is either use the infotainment [which I've found] or buy a fob? The telestart says T91R which is then hooked up to the 'fuba' matchbox size box. When looking through the forum on telestarts, I got the impression that the T91R was for the L405 not the L332? T90/91 was what I needed, and also got the impression that the 'new fob' would have to be coded? I haven't got a BTIId tool yet, I'll come to that on a separate thread.
Alfa Romeo Giulietta Just one Montesa now, 349 White Wonder Austin A40 Farina MK2 1975 Morris Marina 1.8TC 1973 Honda CB250 K4 |
Interesting on the T91R you have. Mine is a T91 but the car is an early 11MY so perhaps they changed the receiver on later ones. Perhaps someone will be along to give us an explanation.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
L405 have a Eberspacher supplied system not Webasto |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
Fox - my Westie has exactly the same kit which says Telestart T91R, and no key fob too. Current: FF Westminster money pit
Bradders: Looking on the 'wiki' it appears a simple process of pairing the fob to the car, seems simple enough once I get a fob [just waiting for Dan to come back with a price].
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 ![]() ![]() ![]() |
Be careful of which remote, my 2011 MY (made in March) has the same receive and I spent a while trying to get a remote to Pair. I think the remote changed as well as the receiver. Interested to see if Dan can source the correct one as I sent mine back to the ebay supplier. There are a number of threads covering this
As much as I'd like to buy one from Dan & help the site supporters, it isn't viable money wise.
Sounds good and hope that works. Let us know will you? |
Good luck with it Fox - keep us posted. Current: FF Westminster money pit
I think I tried with the T91R remote which wouldn't pair with my 12MY. Let us know if you get it to pair.
Slightly disappointed today!
looks like you ended up where I got to. I even tried pulling the power cable on the transceiver and still no luck. I suspect even though its a 91r transceiver you need a 91 remote which seem harder to get hold of. Perhaps someone with a 12MY and a remote that works can post a picture of what they have got.
