Home > In Car Electronics (L322) > Reverse camera repair / upgrade
Page 6 of 7 <1234567>
Mark07Tdv8
England 2007 Range Rover HSE TDV8 Java Black
Morning, I too have the black screen fault and would like to renew my camera. The link for the camera doesn’t seem to work anymore, was wondering if anyone could recommend a good replacement or if this one I have found will work suitably;
https://rover.ebay.com/rover/0/0/0?mpre=ht...3192402306
Thanks
Post #466922 2nd Feb 2018 8:23am
uzp315
Hi Mark,
https://www.ebay.co.uk/usr/parkingsensoron...7675.l2559
I purchased from these guys - they had a phone number on the listing I bought from and it was useful to phone them up and express the need for NTSC only and not NTSC/PAL - it gave me confidence after buying two from other sellers that were advertised as NTSC but turned out to be NTSC/PAL.
From what Miggit says, it seems like there are some different requirements based on the year. I think TDV8s are NTSC, but worth making sure you know what you need.
Cheers Mark
Post #466924 2nd Feb 2018 8:47am
miggit
All the L322 Range Rovers use NTSC cameras.
But on the 2002-2005 BMW non touch screen system you can change the NTSC to PAL with NavCoder, of if your nearish I'll do it for you... as it's not VIN code locked, Whistle unlike other diagnostic tools that I could mention Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #467033 2nd Feb 2018 9:35pm
Mark07Tdv8
Thanks for the reply’s. Ordered the same camera as you have. Looking forward to being able to see something different to the black screen Very Happy
Thanks
Post #467214 4th Feb 2018 9:39am
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
SausageCreature wrote:
Hi Mark,
Cheers Mark
Mark,
The link just goes to the e-bay seller. Have you got a link to the actual camera that you bought?
Glen.
Post #469277 19th Feb 2018 1:04am
uzp315
Hi Glen, sorry it took so long to reply, I didnt realise there was a question and I also thought I had put the details of the ebay seller on here. Anyhoo. As I say, sorry and here is the ebay seller.
https://www.ebay.co.uk/usr/parkingsensoronline
One of his items has this in the text:
Any enquiries please contact:
Tel: 08456431688
E-mail: parkingsensoronlineshop@gmail.com
Post #471896 10th Mar 2018 8:10am
nino_nino
here you go GDM,
https://www.ebay.co.uk/itm/18-5mm-Rear-Vie...SwW5laorVG
Post #471979 10th Mar 2018 3:25pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Hi guys
I have just received my new camera, looking through the posts on here, I understand that you remove all the original bits from the housing, cut the wires, and solder the new connection.
How do you actually fix the camera into the housing, making sure everything is true?
Would appreciate some advice before I start this.
Post #474401 31st Mar 2018 8:38am
uzp315
Make sure you don't cut the new cables before the power converter - the little black junction box where the cables are merged, otherwise you wont get the right signal to the screen.
I glued my replacement camera into the old housing, but you could just wrap it with foam or tape so that it fits nice and snug. In the housing on mine there was round recess that the new unit slotted nicely into. Mark the top of the new unit before fixing into place, so that you can tweak the angle and your view is not lopsided.
Good luck.
Post #474403 31st Mar 2018 8:47am
uzp315
Update/Warning
The camera I bought from parkingcamerasonline ebay account has let water into the unit and needs to be replaced.
They are sending me a replacement today, it's not convenient, but we live and learn. I will seal this one before fitting it.
Post #477738 8th May 2018 11:07am
ThomasKubota
Panama 2006 Range Rover HSE Td6 Adriatic Blue
Hep please
Hi my friends I’m new with this forum. I remplace my rear camera with a Chinese brand that camera come with led. I installed it but always the led are on. I want to know about the cable positive is on always or it is active only when I move in reverse.
Greetings from Panama
Post #531872 22nd Oct 2019 11:09pm
ThomasKubota
Hep please
Post #531873 22nd Oct 2019 11:10pm
ThomasKubota
The led of the new camera always is working help
Post #531874 22nd Oct 2019 11:11pm
ThomasKubota
Post #531875 22nd Oct 2019 11:11pm
LASBAM
Germany 2007 Range Rover Vogue TDV8 Orkney Grey
Hi Thomas,
i have the same problem as you have.
Seems like the LED have the same common ground as camera and react to the Video-Signal of the Navigation-System.
Unfortunately i haven't found a solution yet but will keep you updated...
BR from Germany Current:
- 2006 RR L322 - 3.6 TDV8
- 2022 MB AMG GT BS
- 2020 Audi Q2
Past:
- Ferrari California 30
- 2018 Abarth 595 Competizione
- 2009 Porsche Cayenne Diesel
- 2010 MB E500 Coupé
- 2005 Porsche 996 Turbo
- 2002 Porsche Boxster 986 S
- 2001 Audi S8
Post #571187 28th Oct 2020 8:50pm
