![]() | Home > Maintenance & Mods (L322) > 4.4 tdv8 Snapped drive belt :( |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Car being recovered to home.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Bummer Cheers, Greg
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
In my short time on this forum, think I've read summat about renewing pulleys but can't think why? Is there a mileage recommendation for either pulleys or belts on these? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice! Alfa Romeo Giulietta Just one Montesa now, 349 White Wonder Austin A40 Farina MK2 1975 Morris Marina 1.8TC 1973 Honda CB250 K4 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Presumably you are aware from the Workshop Manual that their are 2 ribbed drive belts .
Thanks GGDR. Indeed.
northernmonkeyjones posted a how-to guide a while back.
Here it is:
I usually eyeball mine every 3 months. Haven't in a while.
Thanks for the links. I will read them when I get home.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Mine's belt is right at the edge of the tensioner pulley and has a dark edge indicating that it is rubbing on the crankshaft pulley at 115K kms. |
I had a look under the bonnet at lunch time.
I'll be checking mine's idlers in a couple of days and if any doesn't spin smoothly then the lot will be replaced when the the tensioner is replaced. They've all done the same work so if 1 is showing signs of wear then the others wont be far behind. |
Glad to hear there wasn't any collateral damage John. |
Thanks Greg.
