Home > Technical (L405) > L405 Adaptive dynamics fault |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2470 |
That will be caused by a brake system fault, possibly a failed ABS sensor or broken wire or a failed steering angle sensor. |
21st Oct 2019 1:57am |
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 57 |
Is this at startup or while driving? Does it clear after switching off/on or after a short drive?
21st Oct 2019 6:22am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
It’s all guesswork without fault codes I’m afraid! There isn’t any common issues like the 322 issue you mentioned above... Well, ahem! Not yet anyway 🥴👍 |
21st Oct 2019 7:40am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Hi Craig, I only have a basic code reader, but this is what it came up with, there was also a reading C0300, but it disappeared before I could screen shot it Thanks Dave
21st Oct 2019 8:04pm |
Just wondering if you got this sorted? |
18th Jan 2020 3:16pm |
Hi qwerty, yes I did thanks, turned out to be the seat restraint module was chucking its toys out, also battery had low voltage, replaced by the dealer and all ok now. |
21st Jan 2020 5:46pm |
21st Jan 2020 8:00pm |
