![]() | Home > Technical (L322) > Restricted Performance fault TDV8 4.4 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2565 ![]() ![]() ![]() |
Very good! The tip to use a clip as a cutting guide is also very good. |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
Two of the intake boots on mine look suspect and non-original and I've had the restricted performance warning pop up (only once, it's gone away now and there was no noticeable loss of performance) so planning on changing all four.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
It's a fairly straightforward job with a few things to be careful of.
This may also help
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Buy yourself a pair of Marigolds and go for it.
Brilliant guys, thanks! Drives:
The oil pipe connections should all be ok, the car had loads of work carried out not that long before we bought it and one of the things itemised on the invoice is a replacement oil cooler and the oil feed pipe. I'll still check mind! Drives:
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
One other interesting thing is that since replacing the boots my fuel consumption has decreased noticeably. I do mainly motorway miles and since purchase it always did about 28mpg which was a bit disappointing.
Result Paul |
This is entirely possible and I'll be interested to see what mine does post repair. That said, it hasn't shown the fault once since that one time last week. Drives:
Jod1rrs Member Since: 04 Feb 2022 Location: Yorkshire Posts: 4 ![]() ![]() ![]() |
Hi all, I have an issue with intermittent limp mode, been into garage and had numerous things done but it hasn’t sorted the issue. I have replaced the boost pressure sensor. But still getting the code P0235 turbo charger/super charger boost pressure sensor circuit a fault. I have been and bought some of the silicone hose to cut down, how easy is it to change them! Hope if this might fix my problem. |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
May need to know whether you have the 3.6 or 4.4 tdv8? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
