Home > Maintenance & Mods (L322) > TD6 - any way to test servotronic valve |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
you could disconnect it and see if that makes any difference.. ... - .- -.
16th Oct 2019 2:04pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Thanks Stan
17th Oct 2019 10:35am |
many years since i did mine but from memory its behind the wheel arch plastic on the off side front.. ... - .- -.
17th Oct 2019 11:03am |
Cheers Stan, will wait for the downpour to ease and climb under there this weekend with a bit of luck |
17th Oct 2019 1:23pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Follow the track rod end inboard & you'll see it in front & above the driveshaft (you'll need the wheel off)
17th Oct 2019 2:44pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Have you checked the uj's on the steering?
18th Oct 2019 11:15am |
