Home > Maintenance & Mods (L322) > wheel arch rubber seal |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Thanks
14th Oct 2019 7:33pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Which picture? |
14th Oct 2019 7:49pm |
Top one. I assume with door shut the 2 seals join nicely up against each other?
14th Oct 2019 7:52pm |
Top man 👍
14th Oct 2019 8:02pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7821 |
LR strips cover all the lip....
14th Oct 2019 9:56pm |
Sorry I just can't get a picture that clearly shows contrast between the outer door seal and the cover strip applied to the wheel arch return. Suffice to say the outer door seal does indeed overlap the cover strip and effectively fully protects the rear arch return. Without the cover strip or the LR genuine part the rear arch is definitely susceptible to impact and potential corrosion. Applying either strip over a liberal coating of grease and cleaning yearly should stop the corrosion. |
16th Oct 2019 2:04pm |
Cheers for all the help Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Oct 2019 3:10pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Good time of year to grease it up.
16th Oct 2019 6:06pm |
No the trim doesn't go round the kink.
16th Oct 2019 7:00pm |
Thanks!
16th Oct 2019 7:03pm |
Order placed for 2 of nicedayforits recommended rubber strips from eBay to replace the existing LR strips in arch and add to front of each arch
16th Oct 2019 7:16pm |
All done today
1st Dec 2019 7:34pm |
