Home > Wheels & Tyres > Odd noise after new front tyres?
Tight777
Had 2 new tyres fitted and since noticed an odd noise.
Sounds a bit like a rubber gater but not sure how it could be a tyre fitters error?
any thoughts
Post #530876 14th Oct 2019 6:38pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
What tyres did you put on? Are they the GT ones? Some tyres do sound different. Years ago I bought a 4x4 (not RR) which had new tyres fitted. Had various diagnostics ranging from front axles to differential and or a faulty gearbox.
Problem solved when tyres were swapped to rule out any rubber issues Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #530927 15th Oct 2019 5:20am
j_rov
They might have bent the dush sheilds and caused a slight rub... very easily done especially if the dush sheilds are rusty. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #530955 15th Oct 2019 9:52am
Tight777
It was the lower ball joint, can only assume it was on it's last legs and jacking it up allowing
it to extend to it's max was enough to end it's service.
Post #544350 18th Feb 2020 8:03pm
