Home > In Car Electronics (L322) > HF radio in L322 (HAM radio) |
ikjos Member Since: 09 Sep 2019 Location: Hornindal Posts: 41 |
Anyone with experience using HF radio in L322?
14th Oct 2019 11:36am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
i've used 446-462 mhz [5 watt] radios in mine for a while now and have had no problems .. ... - .- -.
14th Oct 2019 12:03pm |
VHF and UHF (2m/70cm) would probably be fine, especially with only 5W. But when I'm doing HF (1.8-30MHz) it's 100W and has a much higher potential for causing problems. |
14th Oct 2019 12:30pm |
found this using search,
14th Oct 2019 12:50pm |
Yes, I've seen that one. But is more in the direction of fitting VHF/UHF. Nothing about HF |
14th Oct 2019 12:57pm |
So no special problems with RF interfering with the cars electronic. Sounds promising. Demands of course antenna which is properly tuned.
14th Oct 2019 8:46pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Your antenna has good reviews. |
14th Oct 2019 9:32pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
I have a 477MHz UHF CB in mine with the controls in the mike (main unit behind the passenger side kick panel). The mike is in the sunglasses holder.
14th Oct 2019 9:46pm |
Alinton Member Since: 05 Aug 2019 Location: Kilkenny Posts: 56 |
I'd like to mount my 2m/70cm rig in the glovebox instead of the CD unit, but I can't see how to remove the CD!
15th Oct 2019 10:44am |
