![]() | Home > Technical (L322) > DPF full. see dealer message out of the blue.Sensor failure? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Donut hoses are common. Search you'll find loads.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
As Greg said. Don’t drive it. Get it to a good independent specialist ASAP to read codes and work out what’s wrong with it. It’s usually not the DPF itself but other issues like Greg mentions.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
Thanks guys. I have spent most of today reading all your excellent posts ( |
I guess it's possible.
Have you got a decent independent specialist around you?
Oh also dolphin, again on the best-to-eliminimate-the-basics logic:
Smp68 Member Since: 04 Oct 2018 Location: Verwood Posts: 29 ![]() ![]() ![]() |
I had a similar thing happen to me and after replacing the pipes at the back of the engine it wast sorted. When the engine started to regenerate the pipes stopped it and caused a rapid build up. |
Dolph-post a picture of the top of your engine with the engine cover removed and we can see if you have the original weaker hoses that are prone to splitting. Upgrade is to heavy duty versions |
Fuel was nearly full and drive was over 50 mph and cruising for at least 15 mins.
Read this thread as Greg found a hose issue recently.
sounds like you found the culprit dolphin.
Right,IID arrived and this is the fault code.
Cant find out yet how full the DPF is but does this mean I need a new sensor or just get under and check the wiring (anyone care to guide me where it is situated? Have tried but can't get on RAVE for some reason?) Ps I haven't tried to clear anything yet. OK just found this. No 9 is the badger!
Is there a sensor in the engine bay? (one mech said there was but it may be for another Marque) |
right, got down underneath and checked the sensor codes cleared and no reappearance on start-up.
Non Continuous Soot Mass is the field that shows DPF soot level |
