Home > Maintenance & Mods (L405) > Affordable lift links in the UK
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Very Happy Well, johnson rods are grossly over priced, so I bought a set of these
http://rover.ebay.com/rover/1/710-53481-19...olid=11111
And have to say they are fantastic and do exactly what it says on the tin! Thought I would share as the johnson rods seem to be over priced for what they are. These arrived and the rubber is all genuine land rover and they are like reinforced oem that retain the breakage points as intended with the oem parts. Over all very happy Thumbs Up
I actually use this in harmony with the IID tool. So I have fit them and left the 1.5inch lift, but now I have more flexibility in my IID tool adjustment because I am already starting from a higher position. So for off road or water wading you have a little more reassurance
Post #530646 12th Oct 2019 8:20am
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
Allow fitment of 33" wheels Shocked
And I think my 22's are too big for ride quality.
I'm not judging, just surprised.
Post #530648 12th Oct 2019 8:36am
Charles89
Haha I never noticed that before Whistle assuming they mean 33inch tyres...
I did have 33inch tyres on mine and they were fine with the lift links. But I've dropped down to 32.5 ish!!
Post #530649 12th Oct 2019 8:45am
rn322
United States 2012 Range Rover Supercharged 5.0 SC V8 Orkney Grey
IID vs Johnson rods and a n00b question
If the Johnson rods "trick" the suspension by changing the sensor readings, has anyone simply realigned using the IID tool and the target heights + 40mm? e.g. 533mm instead of 493mm for the fronts and 523mm instead of 483mm for the rear.
Original Standard height values Wheel Centre to lower edge of wheel arch
Front (mm) Rear (mm)
Range Rover L322 493 483
Post #617903 29th Dec 2021 2:26pm
bishbosh10
I was going to say, if you have a IID tool then you can reprogramme the suspension to your desired heights without the need for the rods! Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #617918 29th Dec 2021 5:00pm
