Home > Maintenance & Mods (L322) > Swollen wheel nuts |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
I've done the same recently and I read a ton about the grease / no grease arguments.
6th Oct 2019 10:39pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
After seeing a very experienced lorry mechanic do this many years ago, I have always put copper grease on wheel nut/bolt threads and I have never had a problem. I would rather have them greased and the wheels tightened up well, than have rusty threads that don't torque the wheels up properly.
6th Oct 2019 11:12pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
The copper serves no purpose in lubricating wheel nuts. It's supposed to be used in applications that burn off the "wet" part of the formula, leaving a smooth copper glide surface. The use of copper grease as an assembly paste is a trend, that the manufacturers of such have used for what it's worth.
7th Oct 2019 5:31am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I've put copper grease on wheel studs / bolts for over 50years, never use a torque wrench, just tighten them by feel.
7th Oct 2019 6:21am |
I'm not saying the car's going to melt because you're using copper based anti seize, just that it doesn't serve much purpose as opposed to regular grease. I use it myself when options are not available.
7th Oct 2019 6:59am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
I bought a set of solid nuts off EBay . They are not stainless, but got a galvanised finish which has dulled, but they are still as good as new after 4 years.
7th Oct 2019 8:18am |
Would you mind taking a photo of how they look now, after 4 years? 2007 L322 3.6 TDV8 Stornoway |
7th Oct 2019 8:22am |
No problem, except I am away on holiday for next 2 weeks, so when I return.
7th Oct 2019 10:10am |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 |
Galvanic corrosion innit ?
7th Oct 2019 10:26am |
I’ve been doing it for 50 years because my dad told me to do it never had a problem.
7th Oct 2019 10:33am |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
I researched this a few years back when I had a e46 M3.
7th Oct 2019 7:21pm |
I quite agree on all of that but I do use a torque wrench. Regarding the wheels sticking to the hub, when I first had my BMW 5 Series it went in for new rear tyres. I had not needed to remove the rear wheels at this time and the tyre fitters had a hell of a job getting one of the wheels off because it had corroded to the hub. I have used copper grease since and never had an issue getting the wheels off. Glad I didn't get a puncture before I had the tyres done! |
7th Oct 2019 9:44pm |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
It's best to use copper grease on unlike metal surfaces. If the wheels have never been off or put back on without copper grease then loosen the wheel nuts and drive the car a few feet and that'll loosen the wheel. 2017 5.0 Autobiography Supercharged
8th Oct 2019 7:18am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Impact wrenches are the enemy of RR nuts - they cause the caps to become dislodged from the nut underneath & the swelling starts from there.
8th Oct 2019 8:57am |
