Home > Maintenance & Mods (L405) > Cost of brake pads/linings |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
Find a local LR specialist to do the work and you can easily source the parts yourself.
2nd Oct 2019 2:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
brake pads and discs ,front and rear are a shade over £720 [or cheaper] on the fixed prices from LR.. ... - .- -.
2nd Oct 2019 2:57pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
Do you want to stick with LR branded parts, or are you happy to buy from the OEM supplier (Brembo)? Using LR parts and getting a receipt for fitting from a VAT registered garage will retain the manufacturer’s warranty, but not the Approved warranty.
2nd Oct 2019 5:52pm |
2mm is as low as you want to go on pads. I’m gentle on brakes, but the rear pads are good for 30,000 miles, while I get 60,000 miles from all discs and the front pads.
2nd Oct 2019 5:55pm |
For the best price on LR original prices, contact Dan at Duckworth’s (under the sponsors section). |
2nd Oct 2019 5:59pm |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1234 |
I might be facing a question of honesty... I had two separate video reports , one for the service said A ok , The second for the MOT said PHEW nearly out replace all disks and all pads just 3mm I’m very easy on brakes, I’m at 37,000 - so will get a second opinion ! Thanks for the heads up on the alternative brands Best Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... |
2nd Oct 2019 6:33pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 786 |
Sold my last RR at nearly 50k miles in just under 3 years. Pads and discs were still original. MY23 D350 HSE
2nd Oct 2019 6:44pm |
Bill, definitely worth a second opinion and with the wheels off you should clearly be able to see if they are down to 2mm. The front pads have a huge contact patch and unless you’re a complete hooligan, should be good for some time yet |
2nd Oct 2019 7:28pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
Agreed that 37,000 miles seems low for replacement of pads and discs. My last 322 had about 57,000 miles on it when traded in and still on originals. I can believe that the 405 rears would wear more quickly as there seems much more brake dust on them than on the 322s, presumably the brake force is more evenly distributed on the 405. So unless you live on the sea shore, launch boats etc and get very rusty discs all the time a second opinion would be the thing.
3rd Oct 2019 11:46am |
Bear in mind that the brake pads on the front of the V8 dwarf those on the rear, as they are huge discs with 6 pot calipers. With the greatly increased contact area, they ought to wear much more slowly even if the brake force is equal front to rear.
3rd Oct 2019 12:30pm |
Just reading these posts, all way beyond my pay grade, I have to get someone to do it...
4th Oct 2019 11:57am |
