Home > Maintenance & Mods (L322) > L322 td6 fuel pump change
jefus957
England 2003 Range Rover Vogue SE Td6 Zambezi Silver
Hi was wondering if anyone could enlighten me, taken fuel pump from tank and am wondering what the thing attached to the side of the tank is, it looks like a a cylindrical thing, td6 2003
Post #529323 27th Sep 2019 8:51pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Have you seen the video in the attached link? there is a siphon in the left side. https://www.youtube.com/watch?v=YMWxPwgeLBQ 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #529363 28th Sep 2019 11:18am
jefus957
Hi yes saw that video the piece I’ve seen its stuck to the side of tank by the pump looks roundish in shape but thanks for reply
Post #529367 28th Sep 2019 11:35am
jefus957
L322 td6 Vogue 2003 had starting issue did injector leakoff num 1&4 faulty refurbed all 6 Nu washers/ o-rings good spray pattern, plus nu filter, came to start it but no fuel coming through, in-line pump whirring also in tank pump so decided change tank pump first waiting for it to come then will see if fuel comes through to filter if not will move onto inline pump.
Post #529370 28th Sep 2019 11:50am
wayneg
I changed both my low-pressure pumps last year and the car started pretty much straight away after. You should get just below 4bar pressure reading on the low-pressure side using diagnostics. The sensor is on top of the fuel filter. If there is not enough pressure you will get a fault on the dashboard something like " injector fault" Not sure if that would stop it starting. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #529372 28th Sep 2019 12:10pm
jefus957
Thanks for info first thought it was low press sensor so took pipe off filter no fuel coming out just a gurgling sound inline pump running so plumbed for tank pump fail first thinking of replacing inline pump while I'm doing tank pump change
Post #529384 28th Sep 2019 1:37pm
jefus957
New pump came fitted in ok but a bit fiddly, fitting the other sender/ pickup to the other side took some juggling there’s a Recess on bottom of tank for base of pickup and a hole moulding for top of post ( which is sprung to assist in locating) then the tricky bit arm through hole reaching across tank to fit plug into the pump took 2 tries before it clicked into place got charge battery up refill with fuel and see if it works ( fingers crossed when done) if no fuel appears or no start will replace inline pump and try again....
Post #529587 30th Sep 2019 4:18pm
