Home > Maintenance & Mods (L322) > Rear Toe Ajustment |
Springer Member Since: 15 Nov 2017 Location: Merseyside Posts: 104 |
Hi everyone I have a 2003 TD6 I noticed tyre wear on the outside edge of my nearside rear tyre went for 4 wheel aliment found Toe Links seized so new ones fitted along with new bolts then back for wheel aliment but still can't get enough movement on one wheel to bring needle into the centre of the green on the machine. My question is it possible to reposition the bolt/ washer to give the extra travel needed
29th Sep 2019 3:54pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Re-position: where / how ?
29th Sep 2019 4:38pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
There's quite a lot of adjustment via the cam on the toe arm bolt - obviously enough as far as LR were concerned when it was designed
29th Sep 2019 5:22pm |
