Home > Maintenance & Mods (L322) > Rear Toe Ajustment
Springer
United Kingdom 2003 Range Rover Vogue Td6 Galway Green
Rear Toe Ajustment
Hi everyone I have a 2003 TD6 I noticed tyre wear on the outside edge of my nearside rear tyre went for 4 wheel aliment found Toe Links seized so new ones fitted along with new bolts then back for wheel aliment but still can't get enough movement on one wheel to bring needle into the centre of the green on the machine. My question is it possible to reposition the bolt/ washer to give the extra travel needed
Camber is spot on new bushes fitted 6 months ago
Hope this makes sense await your answers
Peter.
Post #529492 29th Sep 2019 3:54pm
Re-position: where / how ?
Be certain that the outer bolt hole has not rusted away and/or gone or floppy
Had to have one side of mine welded up becuase of this .
Post #529494 29th Sep 2019 4:38pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
There's quite a lot of adjustment via the cam on the toe arm bolt - obviously enough as far as LR were concerned when it was designed
If that's not enough it might be worth checking if something's bent somewhere due to kerbing or some other impact.
I presume your confident the hub bushes don't have lots of play ? That's more likely cause of the tyre wear, but not likely to cause toe to be incorrect unless very bad. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #529499 29th Sep 2019 5:22pm
