Home > Technical (L322) > Coding ABS module
Rewmer
Coding ABS module
Anyone had any luck re coding ABS modules from a different car using BMW software ? Ive got a 2003 FF that I need to swap out the ABS ECU and its coming up CODING ERROR on my IID No7 - 2003 V8 Vogue
Post #528953 24th Sep 2019 6:24pm
tveitan
Norway 2002 Range Rover HSE Td6 Oslo Blue
Hi,
Check out my last post in this topic: https://www.fullfatrr.com/forum/topic49957.html
Tried it on two different modules and it works perfectly. 2002 Range Rover Td6
Post #529348 28th Sep 2019 7:04am
Rewmer
I was so close. I watched a guy doing exactly what I wanted on you tube using scanner 1.4 but when I tried the one box I wanted, programming I think, was greyed out. Also tried progman, but as you discovered it don’t do the L30. I am just trying to programme a spare whilst mine is being fixed, I hope I won’t need to program once I get my original back, but it has been a interesting journey. Thanks for the info on your thread. No7 - 2003 V8 Vogue
Post #529360 28th Sep 2019 8:54am
tveitan
Been there... Laughing
As far as i know, Tool32 is the only way to code for a L322. 2002 Range Rover Td6
Post #529438 28th Sep 2019 8:01pm
Rewmer
I have toolset 32 but don’t have clue how to use it. I found some guides and I can load DSC57.PRG but in the left panel all I can find is cod_lesen and cod_schreiben. Any chance of a idiots guide ? No7 - 2003 V8 Vogue
Post #529462 29th Sep 2019 9:59am
tveitan
I'll try my best. First of all, you need a file called DSC_L30 instead of DSC57. AFter opening the file, you select coden_schreiben. On the right, there is a box where it says Argument. Just below in the white box you type in: 07, E0 then you hit F5 key. Now it should be coded. You also need to calibrate steering angle sensor. Hope that helps, if not i can take some screenshots, but for that i need to connect to the car. 2002 Range Rover Td6
Post #529505 29th Sep 2019 5:45pm
Rewmer
I will have a fiddle tonight. So can I get the L30 file from the car. What is the process to get this ? No7 - 2003 V8 Vogue
Post #529544 30th Sep 2019 7:46am
tveitan
You will find the file in the same folder as Dsc57 is located. If you don't have it, I can try to upload it. You start Tool32, press File, then Load Test. It should open the EDIABAS>ECU folder, and that is where it should be located.
Post #529612 30th Sep 2019 6:34pm
Rewmer
Nope,cannot see a L30 file. If you could upload it that would be a great help. Thanks No7 - 2003 V8 Vogue
Post #529733 1st Oct 2019 6:14pm
tveitan
Yes, as soon as i find out how.. Laughing any advice? 2002 Range Rover Td6
Post #529734 1st Oct 2019 6:22pm
Rewmer
Pm sent No7 - 2003 V8 Vogue
Post #529781 2nd Oct 2019 7:06am
Rewmer
Thanks for the file Tveitan. Getting real close now. Loaded the file and all is good, found the Coderian shreiban , added the arguments as described ( not sure what these mean or are for ) and hit F5 - couldnt connect to the car !
I gave up at this point. Probably just needs the Eadiabas folders re-naming . I will try again tonight.
Thanks again for your help. No7 - 2003 V8 Vogue
Post #530005 4th Oct 2019 5:52am
tveitan
No idea what it means either Laughing I found those codes when I read the config file from another L322 with a working dsc unit.
Did you put the l30 file in the EDIABAS folder where the other .prg files are located? 2002 Range Rover Td6
Post #530023 4th Oct 2019 11:19am
Rewmer
No, just left it on the desktop and browsed for it. Loaded OK exactly as you described. Only failed because connection with the car wasnt right. May have been low voltage as it was showing 11.9v on my headunit. Iknow with some software you have to re name the Eadibas folders to make certain things work. No7 - 2003 V8 Vogue
Post #530024 4th Oct 2019 11:43am
Rewmer
I cant get this to work. I believe i have communication with the car as INPA works OK and I can get info from the ECU using some of the other commands, I even managed to run the pre charge pump, but I cant get it to write to the ecu.
I have had enough for today, will resume at the weekend. No7 - 2003 V8 Vogue
Post #530060 4th Oct 2019 6:21pm
