Home > Technical (L322) > Fuel Burning Heater - Fuses
Markbhai
England 2006 Range Rover Vogue Td6 Buckingham Blue
Hi All
I have a MY11 L322 and the remote heater does not work. This is the heater controlled by remote control.
The remote appears to work OK and pressing it results in the LED flashing green, which is the desired state but the car does not heat. It also does not seem to heat by selecting the setting from the dash with the engine off.
I have read that Fuse 59 can be removed to reset the heater, but my manual says f59 is spare and there is no fuse in situ, so I am assuming it is no longer F59 on a MY11 car. Does anyone know which fuse it is now which controls the FBH?
Regards
Mark.
Post #371101 7th Feb 2016 5:26pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Hi, have you looked on the inside of fuse cover there's a list there on mine
Post #371115 7th Feb 2016 6:53pm
Markbhai
HI
Yes, I have looked on the reverse of the flap, but it only has icons (no text). I have also checked the manual, but can find a description in there that I think might be the FBH. I was hoping someone on here knew what it might be called or the fuse it is connected to.
M
Post #371227 8th Feb 2016 11:38am
J evro
Check fuse 19
Post #371280 8th Feb 2016 6:11pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
just digging up an old thread. have a 12plate L322.
remote flashes red when i try to use the FBH remote.
would like to resync it. as baove fuse 59 in passenger footwell is spare and empty. Fuse 19 is suggested. has anyone tried this?
or is there a fuse in the back that should be pulled?
i have read numerous different ways to sync the remote on an L322 the most common i have found seems to be:
Pull fuse (passenger Fuse 19 i am assuming from above as 59 is spare)
Refit fuse after 5s or more
wait more than 2s but less than 6s then press and hold down off button for >10s until light goes off.
is this correct? Cheers
James
Post #499448 22nd Dec 2018 9:15pm
JST
have also read this, https://www.fullfatrr.com/forum/topic46437.html but i t seems inconclusive for the L322 with various different methods discussed/shown. Cheers
James
Post #499449 22nd Dec 2018 9:17pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I just disconnected the receiver in the offside boot panel, waited 10 seconds, reconnected, press the off button AFTER 2 seconds but before 6 seconds, hold the button for at least 1 second, worked 1st time. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #499470 23rd Dec 2018 5:53am
JST
Sorted now, thank you. ONly slight difference was the remote unit for the Webasto on my 12plate is right next to the fuse box, not behind it. Cheers
James
Post #499485 23rd Dec 2018 11:16am
DrRob
My remote just flashes red for a few seconds then stops. What is the definitive way to pair it to work properly on MY2011.
Thanks
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #529376 28th Sep 2019 12:41pm
DrRob
Ignore me. Found in wiki Thumbs Up Bow down Whistle Whistle Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #529377 28th Sep 2019 12:47pm
DrRob
What does the receiver look like and which wire did you unplug?
Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #529455 29th Sep 2019 9:00am
rjff
The info is in the WM in the Wiki.
2010-2012 WM
Auxilliary heating
Remote pairing
Good drawings, fairly easy and it's suggests the fuse to remove. (Fuse 16, [5amp] in the rear load space cubby fuse section)
Hope it helps. PM me an email if you can't find it and I'll send the file extract. Cheers
Richard
Gap IIDBT
Post #529473 29th Sep 2019 12:14pm
DrRob
Yep! Know about fuse 16 but someone mentioned unplugging the receiver which I assume is a wire feed into a unit... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #529475 29th Sep 2019 1:29pm
Weegie
It is the power feed to the receiver. Just unplugs and is pretty obvious when you look at it. Certainly in the earlier models it is just a little awkward to get to as it is tucked in behind some other bits.. John
GAP iiD BT-Sold
Post #529476 29th Sep 2019 2:05pm
DrRob
OK, thanks. New fob battery to be fitted first then will try again to pair it.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #529486 29th Sep 2019 4:03pm
