Home > General (L405) > L405 thoughts after a month
Ukandrewf
Ok here' my thoughts on the L405 since i bought it (and compared to the L322 previously).
Good
1) performance/ power/ suspension / breaks - so smooth to drive like a different car to previous
2) adaptive cruise down to zero mph make driving in heavy motorway traffic a lot easier / less stressful / arrive fresher
3) carplay and voice control (actually use this with apple phone and works so well)
4) less body roll in corners - reduces stress driving
5) mpg even on 4.4 is noticeably better (can get 30mpg on motorway)
6) massage seats (thought would be a gimmick but I actually use them) hot and cold seats which get hot and cold. (had to turn down heat cause got too hot something i never did before)
7) keyless entry is handy but insecure.
Bad
1) Start stop
2) Sunglasses holder in door ok but not as good as when dedicated at the top.
3) controls like massage seats a little hidden in the software screens which can distract driving.
4) keyless entry - so handy but bad that is sooo insecure.
just my thoughts so far. --
On my third Full Fat RR
Post #528950 24th Sep 2019 5:48pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Not sure if the 2017 is the same as the 2015 but if it is the seats can be accessed by a hard button above the climate controls. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #528957 24th Sep 2019 6:44pm
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
I am a big fan of start/stop... not because I actually use the feature (you can shut it off) but in order for that feature to work, everything has to be overbuilt to deal with the stresses of incessant start/stop. A bunch of overbuilt components doing a fraction of what they're designed to do with the feature off is great. Smile
Post #528969 24th Sep 2019 7:57pm
Ukandrewf
You have access to climate and heated cooled seats via physical buttons which is good. But massage u have to go to the seats button and the select seat, then switch on via software quite a few clicks. --
Post #528970 24th Sep 2019 8:00pm
Ukandrewf
That’s a good point. Just wish u could switch off in software somewhere.
(Signature meridian sounds better with engine off Wink so one perk there too. ) --
Post #528971 24th Sep 2019 8:01pm
brad s1
There is a button next to terrain response on mine... an A with a circle around it. Shuts the whole system off permanently.
Post #528976 24th Sep 2019 8:19pm
dolph34
In the 2015 the seat hard button gives you the seat menu , including massage. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #528977 24th Sep 2019 8:30pm
Ukandrewf
only shuts off permanently for that trip. have to remember every trip to turn off. --
Post #528981 24th Sep 2019 8:38pm
Ukandrewf
it does bring up a picture of the cabin and you have to then press drivers seat (if not selected), massage on (we'll assume the strength is what you want and doesn't need changing), then heated/cooled on and then the amount (potentially six presses to get from hot to cool worst case). Then select passenger and do same if needed.... All of this is distracting.
by contrast the physical dials for climate and pressed for seat heated cooled are much simpler - muscle memory makes it almost automatic. Shame massage can't be controlled on the dial too.
(fully aware this is a first world problem Laughing ) --
Post #528984 24th Sep 2019 8:42pm
brad s1
Weird... Mine is a NAS 2016 and hitting that button just once has disabled the system completely.
Post #528985 24th Sep 2019 8:43pm
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
My just over one month experience:
In to Guy Salmon in two weeks for warranty looks at; suspension clunking (and 4x4i screen shows at any time at least one strut with restricted movement), excessive transmission noise at low speeds (whining), laggy infotainment and partial front screen demister failure. Didn't notice these on short test drive or drive home in car. Time in traffic queues has flagged these up. Shocked Doesn't say much for the pre-sale checks.... Rolling Eyes 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #529083 25th Sep 2019 5:55pm
Ukandrewf
Re: L405 thoughts after a month
Ukandrewf wrote:
BAD
1) Start stop
5) the infotainment screen can't be angled (i think the MY18 version can be) so at certain times of day when sun behind you the screen cannot be read unless you close the roof blind. this doesn't happen too often but i have noticed it. I guess you have to be driving with the sun over your shoulder and low in sky.
6) i find the pillar behind the drivers seat is more forward than on the L322 - making it a little harder getting in and out (..and i've lost some weight!! before you suggest that as a reason). --
Post #529096 25th Sep 2019 6:57pm
Ukandrewf
Triarii wrote:
1)4x4i screen shows at any time at least one strut with restricted movement),
2)laggy infotainment
3)partial front screen demister failure.
1) I'm going to double check mine but i certainly haven't noticed any suspension issues very smooth.
2) fixed by software update...
3) haven't noticed on mine but will watch for it. do you mean the heated windscreen playing up? if the screen was replaced could be the issue.
Andrew --
Post #529098 25th Sep 2019 7:01pm
Triarii
Cars going in later this month. I now suspect the screen issue is the blower having had ducting come adrift on that side. Other issues are still there. 17 MY Corris Grey 4.4 VAB
Post #529871 2nd Oct 2019 6:45pm
