Home > General (L405) > L405 thoughts after a month |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Not sure if the 2017 is the same as the 2015 but if it is the seats can be accessed by a hard button above the climate controls. 2015 4.4 AB
24th Sep 2019 6:44pm |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
I am a big fan of start/stop... not because I actually use the feature (you can shut it off) but in order for that feature to work, everything has to be overbuilt to deal with the stresses of incessant start/stop. A bunch of overbuilt components doing a fraction of what they're designed to do with the feature off is great. |
24th Sep 2019 7:57pm |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 243 |
You have access to climate and heated cooled seats via physical buttons which is good. But massage u have to go to the seats button and the select seat, then switch on via software quite a few clicks. -- On my third Full Fat RR |
24th Sep 2019 8:00pm |
That’s a good point. Just wish u could switch off in software somewhere. (Signature meridian sounds better with engine off so one perk there too. ) -- On my third Full Fat RR |
24th Sep 2019 8:01pm |
There is a button next to terrain response on mine... an A with a circle around it. Shuts the whole system off permanently. |
24th Sep 2019 8:19pm |
In the 2015 the seat hard button gives you the seat menu , including massage. 2015 4.4 AB
24th Sep 2019 8:30pm |
only shuts off permanently for that trip. have to remember every trip to turn off. -- On my third Full Fat RR |
24th Sep 2019 8:38pm |
it does bring up a picture of the cabin and you have to then press drivers seat (if not selected), massage on (we'll assume the strength is what you want and doesn't need changing), then heated/cooled on and then the amount (potentially six presses to get from hot to cool worst case). Then select passenger and do same if needed.... All of this is distracting. by contrast the physical dials for climate and pressed for seat heated cooled are much simpler - muscle memory makes it almost automatic. Shame massage can't be controlled on the dial too. (fully aware this is a first world problem ) -- On my third Full Fat RR |
24th Sep 2019 8:42pm |
Weird... Mine is a NAS 2016 and hitting that button just once has disabled the system completely. |
24th Sep 2019 8:43pm |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 187 |
My just over one month experience:
25th Sep 2019 5:55pm |
5) the infotainment screen can't be angled (i think the MY18 version can be) so at certain times of day when sun behind you the screen cannot be read unless you close the roof blind. this doesn't happen too often but i have noticed it. I guess you have to be driving with the sun over your shoulder and low in sky. 6) i find the pillar behind the drivers seat is more forward than on the L322 - making it a little harder getting in and out (..and i've lost some weight!! before you suggest that as a reason). -- On my third Full Fat RR |
25th Sep 2019 6:57pm |
1) I'm going to double check mine but i certainly haven't noticed any suspension issues very smooth. 2) fixed by software update... 3) haven't noticed on mine but will watch for it. do you mean the heated windscreen playing up? if the screen was replaced could be the issue. Andrew -- On my third Full Fat RR |
25th Sep 2019 7:01pm |
Cars going in later this month. I now suspect the screen issue is the blower having had ducting come adrift on that side. Other issues are still there. 17 MY Corris Grey 4.4 VAB
2nd Oct 2019 6:45pm |
